the piece circled was already snapped off when i recieved the boardXionic said:
Doh!Cuchulain said:Thermalright SI/XP 120 + an Akasa 120mm fan, not only quiet but lowered my CPU temps over the Artic Freezer 64 by nearly 10 degrees.
Note to self.....Ask on forum before buying based on magazine research!!Xionic said:im using quite a small case... will this limit my choices any
heres the inside (minus a gfx card which is in the post)
Xionic said:what about a delta(as i said noise isnt a problem). the pc's in an attic and i use a headset which will drowned out most b/g noise
