Hi all, whats the best mobo for running two 7950 GX2's on at the moment.
We are using an Asus A8N32-SLi at the moment and results are worse than a single card on 3dmark06
Finding this in the mobo manual (2-19, right at the bottom)..........
"Due to NVIDIA nForce4 SLIx16 chipset Limitations, this motherboard does not support two dual-GPU graphics cards (total 4 GPUs)"
is this true even after the required Bios update and chipset driver update?
Anyway, what mobo do you recommend?
Regards
Regards
