Best ADHESIVE thermal pads ?
5 Jul 2007
Looking to attach small ceramic heatsinks and expecting better adhesive thermal tape is available than what is supplied but where do you find it ?. Most are not adhesive. Where are the tests like they do with thermal pastes ?
Thanks in advance.....
I always used to use Akasa thermal tape and never had a heatsink fall off. The trick is to thoroughly clean both surfaces with IPA before using the tape. Where can you pick up ceramic heatsinks from?
