What one of these is the best for cooling my [email protected].
I think the first one on the list is best
Yeah that's one of the main reasons I got the NZXT AIO because of this guarantee. Also compared to other AIOs e.g corsair I find the design on this one to be better...I will be looking for one of these for my next build, thats a good guarantee compared to the 2 years for ones I have seen
Congrats you won't regret it! It is a great piece of hardware!bite the bullet ordered the kraken z73..
What your temps clock speed my 9700k is @5.1 GHz 2 of the cores run away to 95 the others sit in there 45 50. Hoping this new cooler will calm the 2 at 90 down at bit.I have the X73 on an I9 9900KS and it's quiet but performs well when needed.
The warranty was a big selling point they must be confident it will last.
90C!! That is very high. With my CPU and the X73 after heavy gaming for several hours I've not seen the temps above 65CWhat your temps clock speed my 9700k is @5.1 GHz 2 of the cores run away to 95 the others sit in there 45 50. Hoping this new cooler will calm the 2 at 90 down at bit.
The 45 degree difference in temperature between cores would concern me, it could be bad paste application or your cooler is not sitting flush on the IHS due to uneven mounting pressure, however it could also be a fault with the solder between the chip and IHS which would be an RMA (or has it been delidded?). I guess you'll find out when you fit your new cooler.What your temps clock speed my 9700k is @5.1 GHz 2 of the cores run away to 95 the others sit in there 45 50. Hoping this new cooler will calm the 2 at 90 down at bit.
Must have been on the Stella when he put that one together then lolMy setup is a 8 pack bundle the chief him self set the overclock lol.
