Best Air Cooler Under 50 Dollars
28 Jul 2017
I am upgrading to the Realan T3. What is going to be the best air cooler under $50? I'm planning on overclocking to the highest my chip is going to let me.
** Removed competitor link. Please read the rules as next time you may face a suspension - EVH **
Much depends on what case, motherboard and RAM you are using. Really need to know so we can suggest coolers that will fit. ;)
That case is tiny and the cpu is soldered so you are very limited by what you can use, something really thin like a Noctua NH-L9i might fit but you would have to use thermal adhesive to fit it?
Assuming 'Realan T3' is the E-T3. it is only 185(W)*44 (H)*197.5(D) mm .. meaning maybe 22-28mm CPU clearance??
Not many coolers that thin.
That case is tiny. As far as I know there is no room for a fan at all, you basically have a large passive cooler and that's that, which really is not going to allow much in the way of overclocking. I would strongly recommend you go for a larger case if you want to overclock.
Sorry Pocah, but a any cooler that will fit in that case is about 1/8 the size of a 'large passive cooler. :D
Ha ha, yes. I didn't mean large in the normal PC way of things. The ones I have seen for that case are rather like the Noctua mentioned above, they are like a dinner plate with a few fins on and no fan. Not enough room for a fan! A small dinner plate and small fins!!! But yes it's a really tiny case so even the width is limited. As far as I am aware, with all those vents, it's intended as passive. Honestly, I, personally, couldn't be bothered with all that.
