Best air cooling setup for my computer
26 Jun 2014
Hi guys first time poster here and would love your advice on cooling.
I have four fans and a 5 way splitter.
My mobo is a gigabyte z77n-wifi
Ive got four fans and a Bitfenic Prodigy case;
1 Bitfenix spectre 230mm pro (intake at front)
3 Bitfenix spectre 140mm (exhaust at back/top)
The splitter can only read the speed of one fan and this is my issue.
Should I;
Option A - read the speed of the big 230mm and run the 140mm based on the voltage supplied to the 230mm
Oprion B - read the speed of one the 140mm fans, thus the large 230mm would be supplied the voltage of the smaller.
My opinion is that option A would run the smaller fans at a very low RPM at low temps because of the large CFM of the 230mm
Option B would run the 230mm at a high speed during intensive gaming and possibly shorten the life of the fan much quicker!
Would love your thoughts on which setup would be best and why you think so!
Or will it even make a difference!
I think the fan has a reported life span of over 10 years at full speed so I dont think it will be much of an issue running option b
