Best Air flow case for a GTX560TI Twin Frozr
3 Apr 2009
Hello,
I would be very great full if someone could give me some advice as to what the best case would be to replace my Antec 300 with a budget of £100.
I have recently purchased an MSI GTX560 Ti twin frozr 2 and after reading many reviews and my own experience i realized that the GPU Design expels hot air into my case as opposed to the rear as per the norm. this is causing my Motherboard to heat up and preventing further overclocking
I have looked at the Antec Dark Fleet, Cooler Master 690 and the Fractal Design R3 but i cannot decide which one would suit my build.
I have a Asus P8P67 , Intel 2500K 4GB Corsair vengence, a 64GB SSD, and two 1 GB hard drives. This causes air flow problems due to the sheer number of components inside my case. I have two 120mm fans at the front and one on the side blowing cold air in and one 120 mm at the back and the Antec Big boy at the top expelling hot air.
Any advice would be appreciated.
Thank you
out of those, i would probably pick the Lancool or the CM 690 II, the black 600T doesnt appeal to me as much as the white one.
