Best All in One CPU Cooler
6 Dec 2013
Hey All
Just after some advice really, I have never gone down the water cooling route so its all completely new to me but I have an AMD FX 9370 8 Core CPU but I've been reading up that Heatsinks and fans won't cut cooling it, so I want to look at some of the all in one CPU watercooling solutions such as the H100i and some of the OCUK setups.
Money isn't an issue and wanna to know whats the best way to cool my CPU, Basically just want a simple easy to fit kit as I will only be cooling the CPU (Maybe in the distant future the 290X)
Do I just buy a all in one kit or would I buy a kit and then a separate high end block?
Thanks in advance.
Thanks for that link, I'm really not sure what to go for to be honest as I would like to cool my GPU as well but it seems like a lot of work and hassle making and setting up a custom loop considering that I have never tried this before.
Yea it can be a lot of work but once you've don't it the results are usually really nice and you learn a lot from it not to mention that sense of achievement once you see your sexy pc inards :P lol.
But anyway the best of the best for a AIO water cooler would be the custom OCUK ones by miles.
What case do you have as well? Getting a ocuk kit for cpu (I mean the w or v kit) might be a good idea as they provide all you need for a cpu loop but gives you some experience along the way of custom loops. (if you go for one of the better pump kits and your case can handle a larger rad adding a Gpu later isn't that difficult) everybody had a first time
