- 21 Nov 2007
- Fleet, Hampshire
I have recently set up a HTPC in the lounge. This is some distance from the main house PC, so I have gone wireless. I have a Netgear WNR854T 300Mbps RangeMax NEXT router which has draft N spec included.
To get me up and running I went for a standard network card, which I figured would be quick enough for the small amount of browsing done on the HTPC.
What I had not figured in is the file transfer speed between PC's which means that it takes about an hour to transfer a Gig of data.
I figure therefore I need to bump up the wireless card in the HTPC.
Anyone any recommendations. Not bothered if it is internal or USB.
