Best Android streaming box
27 Mar 2006
I'd love to have a play with one of these devices but unsure what regarded as the best of the current bunch. Fully aware of how droids work and would like the extra features android has to offer over say my roku boxes, or my smart tvs. Anyone got any advice. Thanks
ok you have 2 choices an M8 box from the bay based on a quad core amlogic cpu, I have 2 of these and sadly one has died. The other choice an amazon fire tv and are 64 quid at teh mo & these can have their apps sideloaded.
The pros for the fire tv
Better build
read from usb devices
cons
does not switch off
cant be routed
will brick if you try to root it
Amlogic M8
pros
everthing
cons
build quality (depending on releases and copied boxes s82 in an enybox base)
