Best App For Tracking MPG?
19 Nov 2004
Wokingham
Are there any apps out there for Android that help you keep track of your mpg, spending, etc? Ive seen a few people on here post screenshots of their apps but dont know which ones they use. Any suggestions?
I've found tried several and found fuellog to be excellent - the best I've tried so far by some way.
It will cope with just about any measurements or units you throw at it. It copes with partial fill ups, plus non-fuel expenses. You can export to csv files. Worth upgrading to pro for long term use or multiple cars.
With any Android app be sure to back up data before removing it from your phone. If you remove an app, the data goes with it.
With fuel log you must start with a brimmed fill or it miscalculates the next one. After that partial fills are fine but averages only correct after brimming.
And yes Fuel-Log is much better than MPG calculator.
