Best ati overclocking/adjusting tool
  • Thread starter Thread starter T C
  • Start date Start date
T C
T C
13 Nov 2002
'Ull
Hiya,
Just wanting to know what people use or what people find is the best ati tool out there.
I've used the bog standard CCC and riva tuner and for the last couple of months I've been using ati tray tool, but the fan speed control doesn't work with in ati tray tool.
CCC is good but I find it really hogs resources and slows down the pc when leaving games etc where as riva tuner doesn't have enough options for ati.
So is there anything else outthere with the ability to set game specific profiles etc?
My system is as follows: Vista 32bit
Phenom 9950
4gb ddr2 1066
ati 3850x2
Enermax galaxy 1000watt psu (the 3850x2 needs a lot of juice and an 8 pin pcie and 6 pin pcie just to be able to overclock it!)
Thanks in advance.
amd have their OC tool, AMD GPU tool or something, worth giving that one a go. Personally I would reflash the bios with some known stable settings and fan profile, but thats just me :S
Hawker
