Best B.O. basher?
26 Sep 2005
Tonbridge, Kent
I sweat too easily and I'm struggling to find a decent deodorant that can do more than simply mask my manly smell.
So can anyone recommend something decent that will keep me sweat free all day?
Thanks
Ben
make sure you wash your armpits with body wash in the shower in the morning (this is a must imo).
I find that certain brands make me sweat more, i think i use sure for me atm
You'll find deodorant only masks the smell because that is all it's meant to do...
get antiperspirant to stop you sweating as much.
I use Adidas, only one i've tried that actually reduces any sweating.
Sure Men Sport is what I use and it seems pretty decent stuff, I think it is just Physio Sport rebranded (same cans and shower gel containers but different colour) which is what I used to use before it disappeared from the market. :)
I use that Right Guard Xtreme 24 stuff. It works well, even after a stressful day at work. It doesn't have an overpowering smell either.
lynx, strangly. its the only thing that really works for me. i cant stand anti persperants mind.
strage, its still widely available around here. never worked though :p
Haha, well bang goes my theory then unless they are just using up old stocks. I've not seen it anywhere in either Dundee or Edinburgh for about 2 years now so when I saw the same style containers I just assumed that Sure had taken the business over. :)
Sure.
There is only one type that is worth buying - Sport Blast (silver bottle with green writing). It doesn't smell too strong, and hides well beneath Aftershaves. It dries quickly and lasts all day. The other fragrances don't smell as good/last as long or take ages and ages and ages to dry.
You might need some proper stuff from the chemist like driclor, perspirex, triple dry. You put them on at night and wash of in the morning.
Can buy online at places like Boots.
Mitchums is good as well - the roll-on, rather than the dry stick thing. It promises 48-hour protection, but don't expect that if you're going for a run ;)
