best benchmarking programme
12 Jun 2011
hi all i have recently overclock my i7 2600k and added new ram, ssd etc and wanted to benchmark my pc i tried free version of pcmark05 its ran but had issues uploading the results online..
anyone suggest another programme thats good that i can try
thanks
I'd start with prime 95 2.6 or whatever the latest version is and then move to intel burn test if you are comfortable seeing your cpu hit 70-90c depending on what cooler you have.
You could also try Y-Cruncher and Super-Pi if it's benchmarks you're looking for. Nothing will stress your CPU more than Intel burntest though, as the previous poster suggested. And if you want to test all round stability, then run P95 for 8 hours. If it passes, you shouldn't have any hardware issues.
