Best block for GTX 780
22 Jul 2007
nottingham
Hi guys I want to order a water block for my GTX 780 and would like some advice which is the best to go fore please.
I like the look of this one
http://www.overclockers.co.uk/showproduct.php?prodid=WC-196-XS
which ill order with the back plate unless you guys think theres a better one ?
http://www.overclockers.co.uk/searc...ater+block+for+nvidia+gtx+780&_=1376244149711
I like the look of the XSPC Razor because it covers the full card which the other blocks don't look as though they do.
Any input would be much appreciated.
I had a EK block on my 6990 which covered the whole card but the EK 780 blocks look like they don't cover the whole card.
I don't care what the cost I just want the best OCUK have.
Stock cooler idle temps 40c load 80c now with water block idle temp 26c and load 47c so very nice upgrade and the gfx card is on the same loop as the cpu.
Also got the EK block, I did have the aqua block but after shoggy from aqua confirmed that the vrms aren't directly cooled I sent it back. There is more info in the Titan waterblock thread on the xs forums.
