Best budget air cooler for 10600k overclock
First time I've seen the SCNJ 5000 in stock for an age, that's your best bet if it'll fit in your case.
The Mugen 5 mentioned above if not.
Great performing cooler for the money (well, just a great cooler) - and imagine it next to this:
Stacked bricks. :D
I love my windowless cases even more.
Stacked bricks. :D
Very sexy.
If I was spending on a 3080 right now and there was actual stock it's the Aorus cards I'd be looking at personally, or at least between them and the higher tier Zotac.
Scythe SCMG-5100 Mugen 5 Rev.B CPU Cooler £42.95 is hard to beat.
https://www.overclockers.co.uk/scythe-scmg-5100-mugen-5-rev.b-cpu-cooler-hs-046-sy.html
Don't let the picture fool you. The Mugen is a very large cooler. They are very good value for money. If anything the weak link in the product is the fan which is not a particularly good pressure fan. But like any air cooler you can always upgrade it later with a better fan. They really are great value for money.
