best budget case?
23 Mar 2007
hi all,
wondering which case is the best one to get with a budget of £50.
Pref has 2xfront fans, but really just wanting to know what would be good?
A rig with some mild oc'ing will go in, also needs to be able to take 5 hdds.
Last thing, not too big, pref a mid tower.
Cheers.
This week only you can get a HAF 912 for £60 :) A little over, but one of the better budget cases I've seen, and lots of cooling pontential.
Also the best looking but that's a personal taste.
ok...
the cm 690 lite ii is too big for me, i need it to fit unto a cupboard and its just a big,
options are,
antec 200
antec 600
nzxt beta evo
cm 430 elite
antec v 2000
Coolermaster 430 or Antec 300.
Seen both in the flesh and owned a 300. Very small for what it can fit inside. And you can fit 2 x120mm fans on the front :)
