Best budget case
I had a Coolermaster Elite 335 as my case till I moved to a coolermaster HAF 922.
The elite 335 is a very smart and clean looking case. However I paid £26 for it when I bought it. I would recommend that look at the Coolermaster 690 II Lite case as I believe that despite it being above your budget, you do get a lot of good features such as better cable management, Black interiror, mounting options for fans and more space for your components.
Though the elite 335 is not a bad case at all, and at that budget has good build quality.
Nice thanks for the suggestions guys, im thinking about getting the cooler master 334/5, although, what are youre guy's opinions on the coolermaster 430 or the zalman z7?
