best budget cpu cooler
31 May 2010
Bedfordshire
hi guys as above, what would you get to cool a Q6600?
under £20 if possible, but £25 max
also height has to be under 130mm
I got a 92mm OCZ Gladiator fairly recently, it's slightly smaller than my old Akasa 965 but looks pretty nice and performs well with 4 direct touch heatpipes.
Why does the height have to be under 130mm btw ?
the case has a bloody big side fan, thats 25mm deep.
the case itself is only 200mm wide, then there is the gaps at side for wiring etc...
but i changed my mind.:p
i bought a tuniq tower 120 anyway.:D
i decided to take the side fan off, and mount it on the outside.
i know it will look a bit silly, but i would rather have a decent cpu cooler.
nobody else sees the case except for my kids
