Hello all,
Just wanted to know the best Budget CPU for over clocking in a cheap build. I know you will need a Z77 chip set board and the CPU's K series is best for over clocking. Can you OC an i3, pentium, celeron with paying a premium. I'm not too sure on going amd as I will have a dedicated graphics card even though and is cheap and then unlocked. Just confused
Thanks
Jcx50
Thanks
Jcx50
