Best budget midi case?
Man of Honour
17 Feb 2003
Chelmsford
Can anyone recommend a decent case. Budget is around £60. I was looking for the Coolermaster CM690 but it's not available. The Antec 300 looks ok too but not sure if this is classed as a midi.
I'm installing a P35, C2D with standard stock cooler and a 8800GTS.
Anyway, pics would be useful too.
Thanks
i heard lian li skip out on build quality when they have cheap er cases than a 100. have you got this case?
Read my sig - yes :D What's to skip out on? The cooling is fantastic. It weighs the same as a doves feather, looks fantastic. You can fit 3 hard drives down the bottom and 2x 8800GTX in. You've got room for 2 external 3.5" and 4x 5.25" (or like me get a EX-33B and put another 3x 3.5" in the top aswell as one optical).
Perfect for easy modding really. I wouldn't want to go back to anything with a plastic front to it now. Only thing that would be better is if it had a removeable tray like the PC60 but can easily fit my TRUE120 in there so yeh I'm happy with it.
I haven't seen a Antec 300 so I can't comment on it.
We have the Coolermaster you posted above here at work. It gives you the fan - but it rattles a lot. Good value - but value is the key word.
*just read the post above - you get 2x 120mm case fans with PC7+ and room for another 80mm at the top + has air vent in side for graphics.*
Just saw this post on the other thread asking pretty much the same question: http://forums.overclockers.co.uk/showpost.php?p=12454249&postcount=2
The PC-A07B looks pretty good for the extra £10, it mounts the hard drives sideways to the PC7+ and the tray is removable via a thumb screw where the PC7+ uses normal.
It also seems to have a fitting for an additional fan for graphics cooling other than that I can't see any difference
My experience is the build quality is cheap all the way up to £110 but i haven't seen their cases beyond that. Just paying for the name really, they make oem for rocket fish which are soooo much cheaper.
