Hi all
I am familar with the principals of programming (I use VB .Net, ASP, PHP, Javascript etc...) but would like to start looking at C++.
Can anyone recommend a good beginners guide to C++?
Thanks
Have you ever done any object oriented programming, or know any object oriented theory? If not an object oriented theory book with the examples in C++ may be advantageous. . .
Correct me if i'm wrong but isn't VB .Net is an OOP?!
Based on the types of languages you say you have used so far then I think you would be best to spend some time with C before tackling C++ (and therefore the K&R book would be best). I'm sure others can suggest good "intro to c++" type books if you plan to dive right in.
I disagree. I work with people who've moved to c++ from C, and some who've come into the language with no prior experience - the latter are *all* better c++ developers. Less baggage, and less bad habits to 'unlearn'.
Seems like you are focused more on the web development side of languages. Do you want to learn C++ for a specific reason? C# would be my preference to learn for web development language.
Yes I want to start developing applications for Aros.
