Glass said:any matx boards?
yes, but it's max memory performance is limited to ~DDR2 1100 presumably because of the 1067 strap.WJA96 said:Don't forget the Abit QuadGT - all the features of the Commando at 2/3rds the price!
BUFF said:yes, but it's max memory performance is limited to ~DDR2 1100 presumably because of the 1067 strap.
P5B Deluxe/Commando I believe it's possible to get to ~ DDR2 1300 (although the overall performance is unlikely to be any better due to the 1333 strap).
markyp23 said:Pointless post (I don't need to enter a random number to feel cool). It's a perfectly good question as people are spending a lot of money on their stuff and they want to do so wisely.
I do but the OP specifically asked about the best board for testing high end memory & regrettably the QuadGT imo doesn't fill that particular spot.WJA96 said:It's £40 cheaper and for most users (the ones without the £400 RAM) it does as good a job - would you agree?
Shiz said:I am looking for the absolutely best overclocking C2D mobo to test high end memory in.
- I can possibly secure a DS3 or QuadGT for free or even possibly a high end MSI board. Out of those choices, what would people recommend?
