- 18 Mar 2012
- Eastbourne
I'm guessing this would go here but mods please move if not.
I have tarted up my PC with sleeved cables etc, and I ordered some cable combs to go with them but they just didn't hold the cables tight and kept falling out.
https://www.overclockers.co.uk/showproduct.php?prodid=CM-011-EM
It was these ones, for my gpu, motherboard and the ATX pins. They are crap! They say small for BitFenix etc, I have BitFenix cables and they don't fit.
So could you recommend me some decent ones? I have a tool to remove the pins from the plug so can do that if need be.
