best cables for HDTV
9 Feb 2004
wales
Hi guys
I have got a 32" panasonic HDTV and I am using the HD cable that came with the xbox 360 premium.
Is this the best cable to use? Is there a HDMI cable available for it or is there another kind of cable I should get?
Thanks
If your TV has a VGA port you could try the MS VGA Cable.
Is it better than the component cable? Thats a personal choice.
People have commented that the image quality is sharper with the VGA cable but the colours appear a little washed out compared to the vibrant component cable.
I would stick with the HD component lead you get with the Premium Pack.
The difference with a VGA lead would be marginal (if any at all!) for the price outlay.
I much prefer the sharpness of the VGA cable to using the component. The colours are less vibrant on VGA but still perfectly fine.
Also worth bearing in mind that the VGA cable allows several other HD resolutions to be used. So, if your HD screen has a native resolution higher than 720p, then it may be worth it - mine has 768p (effective).
i have the joytech components and tbh i can't see any difference from the component cables that come with the console, kinda wishin i didn't spend 20 quid on them really
