What is the best CAD software for architecture?
I know that the industry standard is Solid Works and AutoCAD.
I want to get used to some kind of program for when I go to Uni and do architecture. I haven't used the above two programs but from what I can tell the learning kerb might be a little steep for now as I just want something I can use fairly easily and casually.
My current CAD experience is fairly basic, I'm pretty good with Pro Desktop/Engineer, and obviously I can use Google Sketch Up easily, as any monkey can. I've heard good things about Rhino, apparently it's easy to use.
What would you recommend? Thanks
