Best Car Checks?
27 Aug 2005
Which is the best company to use for HPI checks on used cars? Theres a lot of promotion around car vertical but are there any other good/cheaper solutions?
Just get a valuation from Cazoo, they run a HPI check to give you a valuation. ;)
Is a good way of free checking potential cars, once you have found a car I'd then pay for a HPI check with a company like Car Vertical etc.
They all seem a bit hit and miss as to which has the best/all information depending on vehicle, etc. Car Vertical is useful in presenting information to quickly digest in detail and for collating in some additional stuff like common things to look out for, etc. but expensive and the results aren't retained permanently (only about a month IIRC) so if you want to keep the information longer term you have to scrape it from the results. (You can save a pdf but the layout is a bit different).
