Two of the special price 7850
Two of them would. But then again, if you're OK with two cheap cards you might as well just get another 660.
Is there any chance of saving for a bit longer for a 280X? Otherwise you're looking at a 270X or a 760.
You reckon a 280x over 770
Dat VRAM.
Yea not sure if the extra 1gb will really be important at 1080p!
Battlefield 4 might respectfully disagree with you on that![]()
2gb VRAM is not a deal-breaker at the moment, but as the two cards will give you similar performance at a similar price, it's one way to differentiate them.
Speaking of BF4: which games do you play? Could be relevant to your decision.
