Best card for £35
10 Sep 2008
Macclesfield, U.K.
OcUK don't stock it sadly! :(
Still, for your needs and budget it may be worth tracking one down! :p
I've used a few, crisp graphics, low power, native HDMI, really good card for the money. If gaming then a used nVidia 8800GT sells around your budget! TBH if its a cheap and cheerful, all purpose, all connecting PCI-E 2.0 x16 DX10 card the ASUS card above is hard to beat!
If you find something more suitable then let us know ta! :)
The 4350 does look good, i can find it in my range, but does OCUK not do something the same spec (and silent) in the 35-45 range.
Just because i know their customer service is realy good, i know some one is on the end of a phone and i will be gettin brand new with manufacturers warrenty.
you need 18 more posts for members market access I'd pick up a second hand 8800gt for £35 ish
Guessing the 4650 gives better performance than the 4350 futher up.
It looks to have a lot of heat sink and a small fan, recon it will be relativly quiet?
Also, 4650 1gb or 9500GT 512 or 9600 512?
