Hi guys whats the best card that could run with a be quiet psu 530w without frying everything else lol
cheers![]()
You really need to list the rest of your system and what you are going to use it for.
If it is the Be Quiet Pure Power L7 530W, I recall reading a review on bit-tech saying that despite the PSU is rated to have a max output of 420W on the 12v rail, in their test they found that beyond around 360W on the 12v rail, the power became unstable.
So with that in mind, I wouldn't really use a graphic card that require one 6 pins one 8pins PCI-E or higher with a i5 2500K on that PSU...the max I would go for is a card that only use up to two 6pin PCI-E. A two 6pin PCI-E card with max power consumption of 225W together with a i5 2500K that consume around close to 100W when overclocked would put it at around 325W on the 12v rail, so it's leave just about enough headroom.
Any card use no more than two PCI-E 6 pin that offer the best bang for bucks, depending on your budget.So what card would you recommend on that psu
Been looking for a couple of days and i havnt made my mind up yet![]()
Ok so i went with this card in the end guys http://www.overclockers.co.uk/showproduct.php?prodid=GX-154-MS&groupid=701&catid=56&subcat=411
Now im thinking of getting another one of these cards.
What would be a good psu for crossfiring these?
Cheers![]()
750w would be a reasonable PSU imo.
