Best card
opps, double nooby post.
When i started out putting a budget together for a pc, i had in mind £100 for a gfx card, didnt work like that, by the time it came round to buying one my budget had doubled and i ended up with a 6950.
I guess you mean the 8800gt and 9800gt? Mate had the 8800gtx, was a good card back in its day, he paid quiet a bit of £££ for it, around £300. Considering you can pick them up for around £50 now, it shows you how old they are. The ones mentioned above are better cards than them
