Best cards for Resolution
9 Dec 2006
@ManCave
the amount of threads we have asking the best card for x resolution i thought it might be an idea. to create a thread and between us create a list.
once the list is generated Kaapstad or a another sole could then use this list to keep it up to date.? saving mutiple threads?
so no trolling is done or if people require a certain feature.
please pick the best card from each company at each resolution example below
1920*1080
Nvidia
Cheap budget 750Ti
Higher Budget 960
Recommended PSU 500W+
AMD
Cheap Budget 380
Higher Budget 380X/390
Recommended PSU 550W+
1920*1200
2560*1440
Nvidia
Cheap budget 970
Higher Budget 980ti
AMD
Cheap Budget 390x
Higher Budget fury
2560*1600
3440*1440
3840*2160
Nvidia
Cheap budget 2 x 970 or 980ti
Higher Budget 2 x 980ti
Recommended PSU 550W+ or 850W+ for 2x.
AMD
Cheap Budget 2x 390x
Higher Budget 2x Fury X
Recommended PSU 850W+
Very good choice for a thread, should be a sticky I think as people will still ask unless the thread is easily found.
2560*1440 = 980Ti
I've used this card on a standard 60hz panel as well as a g-sync panel at the same res, it's totally flawless performance.
the above list is an example, not many have actually posted their thoughts. this is a team effort to save multiple threads.
the majority votes on each card will win & be updated
I guess a lot depends on settings but;
For 3440 x 1440 I use, the Titan X (and I expect 980Ti moreso really) are a great combo. Having said that my Nano and Fury also did reasonably well at this resolution but seemed more comfortable at normal 1440p
