I used to have water cooling, but after an accident of the pump failing, I am back to good old air cooling again.
I am going to be fitting an SI-120 shortly with an Akasa Amber 120mm fan, but I wondered whats the best case fans I can buy? Because having a look it appears I dont have any case fans which is not really a good idea.
So, how many case fans should I invest in? And whats the best sizes/makes?
) would say either akasa fans or ThermalTakes range is quite extensive. Both brands have been reliable for me. As the other posters have said the 120mm fans are best for air movement/noise ratio.
