Best case fan?
8 Jan 2012
Cornwall
I have a antec 300 case and it comes with two antec 120mm fans on the rear and the top was thinking about replacing these with better fans and using the originals on the front and side panel (or the new fan on the side) will this make much difference to temps? And is it worth it?
The fan I was thinking of buying was:
The scythe gentle typhoon 1850rpm it's currently the week special priced at £12.98.(I don't want to spend much more than this)
Any recommendations are welcome just wanna get the best fans I can for the best price.
My comp specs are in my sig.
Went for this in the end to try:
Akasa AK-FN059 120mm Ultra Quiet Venom Viper Cool Fan - 3/4 Pin [AK-FN059]
What are these fans like? They look from the specs to move a lot of air whilst being fairly quiet.
