I have the corsair 300R and am really happy with it Although, a case is rather subjective so it might be worth looking at a few on review sites/Youtube.
I have the z11 . Be wary when choosing its quite fat on the front end. I have a very big desk an due to it being chunky on the front it takes up more room than say the 300R
Cooling is good with the stock fans, but there are spaces for plenty more fans if you need.
I would remove the bottom part of the hard drive cage if you don't need it in as well. The top two slots can be left in and the rest (4) removed. I basically just keep both my mechanical drives in the top slots and my two SSD's are hiding behind the mobo tray.
Great case IMO, if you can cope with having a door on it. Very quiet too and I'm running 2x120mm intake, 1x120mm and 1x230mm exhaust. My previous build was in a CM-690II, which is also a great case.
