Best case for around £30 for cooling?
i am looking for exactly the same thing! unfortunatally i need a pretty big case, anyone recomend a case for max £50 that is fairly large and is atleast 22cm wide?
I recently bought the Elite 430, which I'm going to sell on now, as I have just upgraded to the HAF 912, as it was too narrow for my Silver Arrow and meant that I had to remove my top exhaust fans to make it fit as well, plus there's virtually no cable management.
If I were you mate, I'd spend a bit more for a case, even another £25 or so will make a big difference.
£43 will get you an Antec 100 - much much better.
I've recently got a 430. It is a bit cheap and cheerful, but I think it's good for the price. You could pay more, but it depends what your plans are. I might well upgrade the case in the future, but don't think £30ish is too much to write off (especially if you can sell it on). Better pump the extra £20-£30 into a better mobo or PSU so it'll last you longer. But if you're not on a tight budget, might as well get a nice £50+ case now.
