Best case for Cosair H50-1?
14 Sep 2009
Northumberland
Hi, I want to put this into a HAF922 or something similar. I only have upto about £90 for a case. What would be the best case for fitting this kit into?
Can you stretch to antec 902? Look for something with good airflow and consider using the H50 as an intake as it work's best that way. If you have to use it as an exhaust ensure your case has lots of intake air.
I ended up odding my case to improve the airflow...
If you have a high airflow case it makes minimal difference using a H50 as an exhaust or intake. The HAF922 is a good case so go for it if you like the looks.
