Hi,
Recently built a new system and was on a reasonably tight budget and skimped on the case. (Antec 100).
Originally only had a single card but then soon upgraded to crossfire. I changed both coolers on the cards for Gelid Icy V2's which helped a lot but the room inside the case shrunk further.
Then added an Akasa Venom 120mm fan to the side to exhaus the hot air, this worked very well but very noisy at 12v, (7v and less not really shifting enough air).
So now i want to get a new case but want the best cooling for my cards, ive seen a couple of cases so far with 200mm side fans, (the Corsair 500R and the HAFX). Are there any other cases i should be looking at? Dont want to spend over £150.
600T looks nice but has 4 x 120mm fans instead, not as good?
Cheers
Cheers
