Best case for my hardwares
22 Sep 2018
I have a PHANTEKS ENTHOO LUXE case right now I would like to replace it.
What I would like:
  • tempered glass side panel
  • high cooling performance
  • option for installing AIO (all in one) water cooling system
  • my graphics card is 340mm long(it would be good if 20 to 30 millimeters longer cards could fit)
  • my power supply has a hybrid mode. (Seasonic Prime 650 Titanium) It would be great if the case has a psu cover which has holes for air circulation, because the power supply facing upwards. OR: It is also OK if there is a possibility to remove it.
These are the important thing now.
I plan to replace all house fan to Noiseblocker eLoop B12-PS or Noiseblocker eLoop B14-2 or B14-3.
Thank you very much and sorry for my bad English.
