i will only be cooling nb,sb,mosfets and cup to start with in my first loop the will be going to cool the 3 gpu,s in a nother loop so only be to get to 2x 480mm rads in the case
2 quad rads? good luck getting 2 of those in anything, may even struggle with certain MM cases! go for 2 triples, will be fine with that and a lot easier to fit in.
Like others have said, the Silverstone TJ07 would be your best bet, a quick search on here should bring up some nice examples For some reason OCUK dont seem to sell them anymore
+1 TJ07 can easily take a 360mm rad in bottom and a slimline double in the top with some work (has to be around 30mm thick or less to work ie black ice GTS 240). Other than that as above if you want to go crazy with rads you will need to pay for a mountain mods case or similiar
'only' cooling ..... not much else to cool??? unless you want to get silly with memory w/c, hardrive w/c and if your really mad a watercooled psu... none of which will make any reall difference
the rig i have at the min every thing and a mean every thing is w/c took ages piping up the 4 loops but my system temp under loads is 20C and the cpu under load is 39c
