ive recently just baught the 7970 matrix platinum which was on offer, i will be buying the rest of my parts for my new pc within the next 1-2 months, i just wanted to ask what the best case is, which will enable me to overclock it to the max?
The case won't make much of a difference to the overclock mate.
When buying cases:
Rule 1. Buy quality, something that will last through multiple builds. That means don't be afraid to spend more. A high quality case is an investment.
Rule 2. Buy something you like the look of. The case is the thing you see every day so make sure it's pleasing to your eye.
Rule 3. Buy something that will fit all the stuff you need it to fit.
What's your budget? What sort of features are you looking for? Do you need it to be quiet? Do you need it to have native watercooling support? Do you need it to have dust filters?
Arround £130, I want it looking good and I'm only watercooling my CPU. Thanks![]()
some nice corsair cases to be had in that range, take a look at the 750d coming out soon!
