Best case with watercooling capability
28 Sep 2011
So im looking to replace my NZXT Switch 810 with something different. My case is white and all the plastics on the outside of it got discoloured into this light yellow colour which is annoying. I would still use it for some other pc but right now in search for a new case. Preferably black colour or grey which would support 360 rad at the top and 240 at the bottom or at the front of the case.
Thanks
Depends on your budget and what size case your after. You can make those size rads fit in a midi case or you can easily fit them in a full size.
