Best cheap camcorder?
15 Feb 2009
Bristol
So i'm looking for a cheap (i mean cheap) camcorder at around £100. This is just for basic usage and whatnot, so a £100 camcorder is fine for my needs, before everyone says spend a bit more for best value, etc.
Initially i was looking at the Canon MD205 and the Sony DCR DC51, before it decided to bump from about £120 to £170+.
Then looking at reviews of 'HD' camcorders and seeing a video sample of the Toshiba Camileo Pro HD, I was thinking that getting something similar to this would be better quality than getting a miniDV or DVD camcorder?
Would i be right to say that?
If so, which £100-approx HD camcorders are the ones to consider?
The 2 which stand out atm are the Aiptek AHD200 and the Toshiba Camileo Pro HD. Which do you think is better and/or any other suggestions?
