Best choice for SLI gaming.
17 Dec 2004
UK.
Yeah i'm getting the i7 2600k sandybridge with the Sniper mobo now. x2 EK FC580 GTX Full Cover Waterblock are the connectors I need?
Sorry forgot to change that.
It's now Corsair Dominator GT 4GB (2x2GB) DDR3 PC3-17200C9 2133MHz Dual Channel Kit with DHX Airflow Fan
Never seen anyone go with 4gb of memory when opting for sli 580 system.
You need atleast 8gb and as prices are so cheap why not go for 16gb?
I assumed the corsair gt's were the better chips, but getting 2 sets would have gone over budget. Didn't want to skimp but if not loosing anything I'll get the 8gig set or 16.
Make sure you buy the EN versions of that GTX 580 block :)
Mobo wise, I suggest the Asrock Extreme 7 Gen3, IIRC, it has better features than th Gigabyte
If you have any cash left over, I would get the Xigmatek Elysium instead of the HAF X
