Best compatible router for sky adsl
7 Jan 2010
Up NORTH
Hi all
As above anyone recommend a good wireless n router that will work with my sky modem, the
sagemcom-f-st-2304n
Thanks
So you want to use the supplied modem/router/access point just as a modem and add a router/access point to handle your network?
Why not just use the router, it has a built in 4 port switch and wireless.
Unless you want another switch further away?
Im confused :confused:
Sorry all
I've confused myself with this
I'm wanting to replace the modem with best compatible modem
As the wireless signal in home is rubbish
Sorry all
dont complicate matters just get a wireless access point
http://www.overclockers.co.uk/showproduct.php?prodid=NW-030-TP&groupid=46&catid=1837&subcat=
however the sky router is not totally rubbish if you are not getting the range you need replacing it will probably not help.
I believe there is a way to get the routers login details so you can jsut reaplce the router for another one...
