- 10 Mar 2006
- Northern Ireland
What is the best cooler to replace the stock cooler with on an ATI X1900XT-X?
At the moment the best cooler is the stock one, once its been lapped, long thread on [H] . I've read that the AC cooks your motherboard (DFI anyone?) and ups the case temps (reports on XS of it killing a card). The vf700 can't handle the x1900 wattage, loads of reports of the temps going up. Wait for the vf900 see how that gets on, does look a bit small tbh. Water's about the only real option at the moment, 150w full load is a lot to dissipate with air without a cpu sized HSF (which has also been done.)xknight2000 said:What is the best cooler to replace the stock cooler with on an ATI X1900XT-X?
fornowagain said:At the moment the best cooler is the stock one, once its been lapped, long thread on [H] . I've read that the AC cooks your motherboard (DFI anyone?) and ups the case temps (reports on XS of it killing a card). The vf700 can't handle the x1900 wattage, loads of reports of the temps going up. Wait for the vf900 see how that gets on, does look a bit small tbh. Water's about the only real option at the moment, 150w full load is a lot to dissipate with air without a cpu sized HSF (which has also been done.)
All that heat pumped into the case and not out the back and it doesn't change your case temps? No thanks, just what you need 150w dumped on the northbridge.chovi said:disagree totally with what you said, ive not noticed any changes in my temperatures what so ever! anyone else ?
Its 150w overclocked (approx), nitpick all you like. It's simply a bad design, I don't need to buy it to see that its going to push hot air on my boards chipset fan. I've been following cooling options since the day x1800's were released. I think yours maybe the only report that I've seen (where they took readings) so far where it hasen't increased the PWN/NB temps. Still every rig is different, wonder what will happen if the ambients go up. All that heat energy has got to go somewhere, must be great case air flow.chovi said:125 but thats nit picking. Unless you have one installed in your machine your not exactly in a position to say if its right or wrong.
Lol, I'm more than able to buy something untested if I like the design. I'm an Engineer I've designed heatsinks for cathode heat dissipation in the Kilowatt range, 2MW rated glass production lines. Believe me, it doesn't take a genius to see the limitations of that awful Accelero design. They could have vented the air anywhere (out?) but down, daft.chovi said:well i have pleny of ventiliation and know my case is up there the the best of them ( kandalf ). maybe your right maybe i am one of the lucky ones., and yes each rig will be different of course but i think you`ve still got to try things for yourself from time to time rather than read differing opinions of others.
chovi said:er, i wasn`t having a dig in that last post btw!! I think the original thread starter has left the building !!!!!!!!!!!
Bennah said:This stuff about the mobo getting cooked because of the AC, thats rubbish tbh. I dont believe that one bit.
Its the amount of heat over a given area (and air velocity). The air flow for the SP-120 moves through 120x120. What's the area for a the GPU slot cooler? 1/5? And how close is the exhaust exit to the board. On some boards its going to raise the temps enough to lower stability. And down by the bottom of the Accelero where is the case flow, out the PCI slots? Not without help. The NB area is already heat loaded, its not designed to have more heat poured on top of it. What's sad is that its so easily designed better and they should know from the last gen of coolers.Bennah said:Im not saying it wont get hot. Im just saying that one example doesnt count for them all. Good air in a case would help a lot. Would be blowing air over the nb sink anyways. Having said that, have you seen the nb sink. Its not exactly good its self. So it wouldnt be drawing much heat out anyways. They dont get that hot tbh. So added heat onto it wont make a matter, I dont think.
