best cooler for core 2 duo
I'm getting a Thermalright HR-01 in a few weeks for my core 2 duo.
Check this thread. Should be of use to you :)
I would go for the HR-01 Tuniq or Thermalright Ultra-120!
i think i will go for the ninja or tunqi tower cause they seem to come up the most often, plus thermalright are hard to find...i'm buying from a competitor (im from n.i and have to shop a little more local)
so between the ninja and tower what is better? or are they equal? does it call just come down to what i think looks better? btw what is easier to fit?
what thermal paste should i go for? or do they come with them stock?
What do the competitor's extremely expensive to run high volume forums suggest you buy? One of the great things about living in NI is that GB based companies ship to you at the same rates as the rest of the UK, so there really isn't any reason not to buy mail-order from OcUK.
