Best cooler for P4 3.2 ghz lg775 on DFI Lanparty
Well if you have no budget then you should get water or phase :p but if you want a normal HSF then I would recommend Arctic Cooling Freezer 7 Pro for only £15.
I use the AC Freezer 7 Pro, get 35c idle and 42-45 load.
I would really recommend it.
-If I open the case, whip up the fan to full speed and put a desk fan infront of it, I can get it down to 26-27 idle - lol
on the cheaper side is the artic cooler 64 or 7 pro.
then i would suggest either the big typhoon or si (or xp) - 120.
above this is scythe ninja (if it will fit into ure case).
beyond is the realms of water and phase.
