Best Cooler
1 May 2006
UK
Guys ive got a x800gto need a cooler for it...ideally one that will function well at low rpm...but which in your opinons is the best video card cooler on the market cheers :p
The Zalman VF900-CU is the best cooler out in my opinion, second only to the HIS IceQ 3 which wouldn't be a viable option here. The VF900-CU has very similar performance to the Acellero X2 but doesn't blow hot air directly at your motherboard.
LoadsaMoney said:
Oh btw, Welcome back Ulfhedjinn, i seen you had been banned. :confused: :p
Off-Topic Mode: Aye, it was actually a seven-day suspension for shop talk. ;) Back now though, and won't be making that mistake again any time soon. :D
On Topic Mode: The only problem with the VF900-CU is that it doesn't exhaust air out of the case, but if you have a half-decent cooling setup (I have an 80mm intake and two 80mm exhausts in my case, but a single 80mm exhaust would work wonders) then you won't have any problems with ambient temperatures. It's also stupidly easy to install or remove. :)
