what do you think of the thermaltake cases with preinstalled wc kits?BlackDragon said:With a budget of £200 you could get a decent case and a water cooling kit...but the WC kit won't be very good. Best off getting a decent case with good airflow and a very good CPU cooler.
Maybe Antec P180 and Noctua U12F/Tuniq Tower/Thermalright 120 Extreme.
Other cooling stuff you can purchase as you need them
yep thanksBlackDragon said:My knowledge on watercooling isn't great so ill do my best to help out![]()
Best thing to do is to try and find some reviews on the case to see how good it is at cooling your hardware. Having your WC setup crammed into the case may mean sacrifices may have been made, such as a smaller radiator or whatever, which of course has a detrimental effect on cooling. Of course its possible to do it right if you have a big enough case.
Another problem with built in watercooling is that if a part breaks (like the pump) you've gotta source a replacement which could be easy if the placement of the part can easily be replaced by something else. But a mate of mine had a case with built in watercooling and his pump broke down, he was unable to source a replacement pump so ended up having to go back to his stock cooler!
Just wondering, are you planning on pushing your hardware really far? IIf so, save up some money and piece together a really nice WC setup. If not then buy yourself a case with good airflow and a good CPU cooler which in most cases in suitable for whatever you want, even for overclocking.
Well i hope i've helped a little![]()
lol well i don't really no much about water cooling setups, not sure which parts are good and which are a waste of money etc..BlackDragon said:As its a quad core it'll probably be quite hot, and at them speeds you'll definitely want good cooling to keep the temps comfortably low. If you can try and piece together a good WC kit with the help of the forum members![]()
yantorsen said:best cooling for under 200?
air or water, need a case and other cooling hardware... cpu cooler gpu cooler, chipset cooler (if applicable?)
thanks![]()
Not to wee on your fire but 3.2 with a 2.4 chip isnt going to create much heat as its a small OCKingy1968 said:I've got a Lian LI PC7 case and a Q6600 with a Thermalright Ultra 120 Extreme with a Scythe S-Flex 1600RPM fan..
Mines running stable at 3.2Ghz and the temps are 46oC idle and 58-62 stressed..
pegasus1 said:Not to wee on your fire but 3.2 with a 2.4 chip isnt going to create much heat as its a small OC
I was just stating that for £100 he could get the same results as mine..pegasus1 said:Not to wee on your fire but 3.2 with a 2.4 chip isnt going to create much heat as its a small OC
yantorsen said:yep thanks
im just wanting to oc a q6600 to over 3ghz really perhaps 3.2... but i want it rock solid stable cuz i cnt afford for anything to go rong.
As Paradigm says, at that OC it should still be on stock volts therefore producing little if any more heat than a C2D.Keeny1979 said:you missed the point - its a quad core running at 3.2
